Old 05-05-2004, 07:22 PM   #1
MotoPhoto
MotoPhoto's Avatar
Super Cool Since: Jan 2004
Locale: Klamath Falls, OR
Postings: 2,192
MotoPhoto is on a distinguished road
Angry HELP!! BROKEN KILL SWITCH!!
I was backing my bike (KLR650, 2004) in at work and had the bars swung to the right. The emergency cut off switch (kill switch) got caught on one of the loops on my Wolfman tank bag. Did not notice it and when I straightened the bars, well I found seven red parts and think I am missing one of the springs
Does any one know of a temporary fix, if so drawings would be good?
Also will need a replacement, any after market that are better and or cheaper than stock.
Thanks for any advice
Craig
KLR 650 - A18
Triumph Sprint ST - 2008
Polaris Sports Man quad
KLR-650, it's a great do-it-all bike which excels at nothing; except being able to do everything
MotoPhoto is offline   Reply With Quote
Old 05-05-2004, 07:26 PM   #2
UK Rob KLR650
UK Rob KLR650's Avatar
Super Cool Since: Jul 2003
Postings: 2,000
UK Rob KLR650 is on a distinguished road
Default
To be honest ive never really looked iside the switch to close but i'd say find the wires that go to the switch (one each side obviously), cut them and then just twist them together. Im sure it aint as simple as that but i cant see it being much more complicated. Maybe a bit of trial and error but its only a quick fix and to be honest i never use my Kill switch anyway so cant see why it cant be a permanent one.
UK Rob KLR650 is offline   Reply With Quote
Old 05-05-2004, 07:37 PM   #3
JimO
Super Cool Since: Feb 2004
Postings: 13
JimO is on a distinguished road
Default
Actually the kill switch grounds the ignition to stop the engine.
There is a Black and white striped wire going to the kill switch.
Disconnect is somehow.
If you just cut it , make sure you cover the ends with tape.
or you may find yourself looking for the cause of a misfire.
JimO is offline   Reply With Quote
Old 05-05-2004, 07:51 PM   #4
fixer
Rank: Expert
fixer's Avatar
Super Cool Since: Sep 2003
Locale: Lost Wage$, NV
Postings: 13,606
fixer will become famous soon enough
Default
looking at the wiring diagram in the Clymer manual, the kill switch has two sides. AKA: double pole single throw (switching it left or right makes and brakes the same cirucits)
the two brown wires and the black/yellow wire should be normaly connected.
the black/white wire should not be connected to anything.
have you pulled your doohickey lately?
KLR 650: Dirt Ninja KLR 250: the ugly duckling, undergoing rehab
√ote Libertarian!
perpetuate the KLR stereotype, visit the Deals Forum
fixer is offline   Reply With Quote
Old 05-05-2004, 07:54 PM   #5
UK Rob KLR650
Postings: 2,000
Default
Yeah, thats what i meant
(Bugger, must read my Clymer manual so i can say helpful things to )
Old 05-05-2004, 08:25 PM   #6
MotoPhoto
MotoPhoto's Avatar
Postings: 2,192
Default
Need to buy a Clymer manual, are they out for the 04's yet?
So do I need to cut the two brown wires and the black/yellow wire and connect them together?
Am I looking at buying a new one from the dealer or would aftermarket be better?
Craig
KLR 650 - A18
Old 05-05-2004, 09:34 PM   #7
fixer
Rank: Expert
fixer's Avatar
Postings: 13,606
Default
no changes to the '04 except for color, the Clymer will work fine.
yes, if you cut the the black/yellow wire and both brown wires off at the switch and twist/solder them all togeher, then just cut the black/white wire and insulate... and tape it all up you should run fine... no kill switch, but there's always the ignition. a new switch will have new wires.
don't know about a generic kill switch, but the same switch is probably used on MANY Kawis... and perhaps somthing from another brand might fit... and could certantly be made to work.
the part you need is-
Part Number: 27045-1071
Description: SWITCH-ASSY,ENGINE ST
Price: $40.66
http://www.ronayers.com/browseparts....ing=27045-1071
however Ron Ayers and FedEx Ground take about a month when i order parts... Fred at . (or your local dealer) may be able to get it faster... or try a bike salvage yard. that switch is the sam for ALL years of KLR.
√ote Libertarian!
Old 05-07-2004, 10:10 AM   #8
Marty
KLR-a-holic
Rank: Expert
Marty's Avatar
Locale: Just South of The Ocala National Forest
Postings: 5,747
Marty is on a distinguished road
Default
Moto_Photo,
I would take it to my dealer on bended knees and tell exactly what happened.
After reading the warranty, DUMB MOVES on part of the owner are kind of in the grey area.
But first, buy a Kawasaki tank bag and tell him that is what did the damage.
Marty
The "Doomeister"
KLEX-500 (project)
KLX-331S
KLR-650 A18
DL-1000 K6
~ How come you never see a motorcycle parked in front of a psychiatrist's office? ~
Marty is offline   Reply With Quote
Old 05-07-2004, 03:00 PM   #9
DoubleD
Super Cool Since: Apr 2004
Postings: 86
DoubleD is on a distinguished road
Default
Marty, I like your answer best.
Cheers /DD
DoubleD is offline   Reply With Quote
Old 05-08-2004, 12:35 AM   #10
MotoPhoto
MotoPhoto's Avatar
Postings: 2,192
Default
Picked up my new switch today, will install it in the morning.
Fixer thanks for the info. Also ordered a Clymer manual should be hear Monday.
Craig
KLR 650 - A18
Old 08-31-2011, 08:56 PM   #11
pjconstruction
Super Cool Since: Aug 2011
Locale: grovetown ga
Postings: 14
pjconstruction is on a distinguished road
Default Re: HELP!! BROKEN KILL SWITCH!!
99 klr 650 kill switch bypass wiring help please
pjconstruction is offline   Reply With Quote
Old 09-01-2011, 08:14 AM   #12
ghotioutofh2o
Phlying Ghoti
ghotioutofh2o's Avatar
Locale: 710,582.88 KLRs 15 deg TN Spnbt'
Postings: 1,280
ghotioutofh2o is on a distinguished road
I wouldn't recommend bypassing your kill switch unless it's broken and you need to ride in the meantime, but if you must, I think fixer explained it well: http://www.klr650.net/forums/showpos...70&postcount=7
Why yes, I have pulled my doohickey lately. It's even caught on camera!
"Live and learn" should be rephrased to "Learn, if you live."
Everyday is a great day to ride.
Вce хорошо, что кончается хорошо.
'98 KLR 650, ever so affectionately named Leah - 27,000 smiles so far
Previous bikes:
'78 AT1 125, "sold" to my brother
Mixture of '87-'88 YZ 100/125
'?? Yamaha Virago 250
ghotioutofh2o is online now   Reply With Quote
Old 09-01-2011, 01:23 PM   #13
pjconstruction
Postings: 14
Bit I did do it exactly like he explained and now it turns over but no fire to coil.
Old 09-01-2011, 03:57 PM   #14
pjconstruction
Postings: 14
I did just as he explained now it turns over but no power to coil.popped main fuse twice then stopped and returned to klr forums for more advice.
Old 09-01-2011, 08:55 PM   #15
ghotioutofh2o
Phlying Ghoti
Postings: 1,280
Price: $40.66
Ok, so I didn't check fixer's work before I gave his advice.
The two brown wires need to be connected to be able to start the bike. To turn off the bike, ground the black/white.
*CONNECTING THE BROWN AND BLACK/YELLOW IS SHORT TO GROUND* That's why you blew fuses. Sorry for your confusion.
Note to fixer: in the wiring diagram, the line between the two halves of the switch signifies that they are mechanically connected, not electrically connected.
Previous bikes:
Old 09-01-2011, 10:33 PM   #16
pjconstruction
Postings: 14
What could mess up if ya kept trying it? (Shorting to ground) I still can't get it to fire
Old 09-02-2011, 07:22 AM   #17
ghotioutofh2o
Phlying Ghoti
Postings: 1,280
As long as you keep replacing the fuse with the same amp-rated ones (I'm guessing the 10A fuse is the one blowing?) nothing. The fuse should be committing suicide before anything else gets the chance to blow up.
Previous bikes:
Old 05-20-2013, 05:20 PM   #18
Steve2005KLR
Super Cool Since: Jul 2011
Locale: Ontario Canada
Postings: 4
Steve2005KLR is on a distinguished road
I did this too trying blindly with different wire combinations. Mine has b/w wire. It comes from the stator. Just cut it loose and insulate it good. The black/ yellow is ground. Also insulate it. Connect the orange wire after cutting it loose with the brown one. This connects it through the switch to yellow red. When you push the button it should crank and fire. Trouble is I heated too many wires and popped too many fuses up in the bush trying to avoid a long hike out through bear country. Now I think I damaged a coil or cdi or something. Anybody have any idea what's most likely. I have cranking but no spark.
Steve2005KLR is offline   Reply With Quote
Old 01-09-2014, 11:51 PM   #19
Frakis
Super Cool Since: Sep 2013
Locale: Houston, Tx
Postings: 2
Frakis is on a distinguished road
Thanks for the solution Steve. Your wiring solution was spot on.
Frakis is offline   Reply With Quote
Old 04-14-2014, 12:41 PM   #20
Capt. Red Beard
Capt. Red Beard's Avatar
Super Cool Since: Nov 2013
Locale: Northern Colorado
Postings: 213
Capt. Red Beard is on a distinguished road
After reading a handful of different folks trying to solve this problem, I was still not very sure what was the best way of bypassing the kill switch. I found others explanations of how the switch worked, and different ways of doing something so simple confusing. So I thought I'd try to make this as simple as possible for those of us who just broke the red off-run-off kill switch.
I can only speak from what I have just done, so this info is from a 98.
To bypass your kill switch (mine broke off after a crash. starter button still intact)-
You will need: A large Phillips screwdriver, wire stripper, wire cutter, scissors, and electrical tape.
Step 1. Remove the Start and Kill switch housing from the Mirror mount. Tilt the handlebars to the left for room. Use the Phillips screwdriver to unscrew the single screw between the Start button, and the Kill Switch. After the screw is removed, carefully lift and remove the housing from the Mirror mount.
Step 2. Using the wire cutters (or scissors, knife, etc.) disconnect the Orange wire (not in the Big Cee wire diagram), and the Brown wire. Do this as close to where it is soldered for the most length to work with.
Step 3. Strip the Orange, and Brown wires leaving about 1/4 to 1/2 and inch of exposed wire. Twist them individually Clockwise.
Step 4. Connect the Orange and Brown wires. Solder, or twist them Counter Clockwise. Insulate them with Electrical tape (or something similar)
Step 5. Test Start. Before putting it back together. Turn the key to the On position, and press the Start button. It should start up as usual, if not you'll need to continue to troubleshoot. If it does start, carefully put the Orange, and Brown wires back in the housing, and re attach to the mirror housing.
Hope that helps!
-Cap
I always find it easier to smile on two wheels...
Capt. Red Beard is offline   Reply With Quote
